Code P0102 MAF or VAF check low input
1996 Volvo 850 Turbo Wagon. It starts, it surges and stalls out... Any advice on this situation would be a HUGE help. I am not even sure what a VAF is? Unplugging the MAF did not make any difference.
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
I have been also having MAF sensor problems and I found out from a Volvo specialists that the off brand maf sensor I put in there is usually not so good that they only use the Bosch factory spec Maf sensor. I got mine from IPD on this site for a pretty good price, it only took me about 5 minutes to change. You said it didnt matter if the connector was on the sensor? no change in the way the engine ran? Is that right? If so then that could be your problem, you should hear the engine bog down after you remove the connnector from the MAF sensor and mine at times would stall trying to put it back on. Also before you invest all that money for a MAF sensor I would look for any hoses from the air filter box to the throttle body for any cracks that can give bad signals to the engine computer for air fuel ratio. Vacuum lines can also cause that code. Good luck!
Flybri15
"97 volvo 850
"97 volvo 850
- 3103 Views
Last post by itsmekirby
- 2010 Views
Last post by Scholz
- 3350 Views
Last post by Billbrink
- 777 Views
Last post by goVolvo
- 1274 Views
Last post by alschnertz
