New to Volvos, got some questions
Dan
Post by Dan »
I just bought a Volvo 850 94 sedan. My "check engine" light came on (which I have come to find out happens alot) and was wondering if I need an OBD II to turn it off? I've read some stuff online but its a bit confusing.
Also, recently my engine has cut out on me-- once when I was idling and once on the freeway (Yikes!). However when I turned the car off and restarted it there was no problem, and has been fine ever since. Could this be a computer problem related to the "Check engine" light? I could always take the car in, but I'd like to do this kind of thing myself, if I can.
Any advice would be appreciated.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
You don't need a tool. Just a pencil and paper to write down the codes your Volvo will give you.
http://www.troublecodes.net/Volvo/
Also -> Amazon link
Dan
Post by Dan »
I forgot to mention that my car is a turbo...
White850Turbo
Post by White850Turbo »
The code socket thing for the 850's is up near the windshield washer reservoir. Check the codes for each socket and let us know what you get.
-Sean
1998 S70 T5 (Almost Stock)
Jot
Year and Model: C30 2010
Post by Jot »
If you disconnect the battery for a couple of minutes they will be cleared You will need to reset the radio code and clock
Dan
Post by Dan »
So I ended up buying an Actron Pocket Scan OBD II reader. I got the code PO44O. The Volvo Chilton Manual says that this is a "canister purge (CP) valve leakage", but the manual that came with the device says that it is an "EVAP emission control malfunction". Which one is it? Is the Actron device compattible with Volvos? Should I just use the Chilton manual? Depending on which problem it is, how do I fix it?
White850Turbo
Dan wrote:So I ended up buying an Actron Pocket Scan OBD II reader. I got the code PO44O. The Volvo Chilton Manual says that this is a "canister purge (CP) valve leakage", but the manual that came with the device says that it is an "EVAP emission control malfunction". Which one is it? Is the Actron device compattible with Volvos? Should I just use the Chilton manual? Depending on which problem it is, how do I fix it?
The evap valve problem is very common. It's just the little black valve attached with a bracket to the fan shroud on the driver's side of the car. It has a hose attached to each side and an electrical connection on one side also. You can get a replacement one from FCP for $75.
-Sean
Dan
Post by Dan »
So are the 2 different definitions for the codes really the same thing?
White850Turbo
Dan wrote:So are the 2 different definitions for the codes really the same thing?
jupp
-Sean
