JLR, San Juan, P.R.[/b]
Disable daytime running headlights in S40 T5 2005
jlrs40t52005
- Year and Model:
- Has thanked: 2856 times
- Been thanked: 1332 times
Is there a micro screw-switch on the light switch panel? Many (most?) 850s have this. The small screw turns on/off the DRL feature.
Guest
Tnx's sir. I recall seeing an article in this forum asking for the same solution but foa an 850 model. I just dont wanted to try it since i am new to the volvo family with this car. I will see if it works and let u know soon.
Jlr, San Juan, PR.
Jlr, San Juan, PR.
Guest
Hi Matthew1. I have checked the switch over and over and there is no small screw to disconnect the xenon lights. Actually there is only the harness connector and wires that go to the switch. Also i have checked this issue in other volvo forums and they suggest me to take it to the dealer since the disable process is via computer software, and they can perform it. My local dealer does not perform this operation because it can cause the computer to loose the factory programming in other circuits. So here i am in cached 22 with the xenon lights allways on during the day. Is there any wire in the switch that can be cut to get the same results? Let me know...
I don't know enough about S40s to tell you where to go from here.
Perhaps try Volvo parts dealers (including my sponsor, MySwedishParts.com) to find out if there's a S40 part number for a light switch that does have a microswitch to disable DRL.
That is about all I can suggest.
Frank Patrick
North American bound Volvos are programed (N)- wich imparts an open circut, though slighty les amps, to the low beam on zeon equiped vehicles.
This feature can only be changed with a re-program- I not sure what the dealer was talking about, when he said it would damage his computer equipment, it's design to do this. That said, why would you want to? This feature has proven to save on collisions, it has a virtually no effect on energy/wear and tear on the vehicle, but could save your life. I'd leave it on.
- 865 Views
Last post by Snaab
- 2352 Views
Last post by Liliflower
- 1062 Views
Last post by dikidera
- 5236 Views
Last post by PEA
- 3434 Views
Last post by ShadowDancer
