socket for oil change?
jamestkirk
Year and Model: V70, 1998
Post by jamestkirk »
Changing my oil for the first time and don't have the correct size socket (don't have any metric ones). What size do I need?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Should be a 17mm.
'98 S70 T5
2016 Chevy Cruze Premier
jamestkirk
Thanks
FCPEURO
Year and Model: 2006 XC90 V8
Post by FCPEURO »
You could also try a 11/16th size. That is the closest thing to 17mm.
jamestkirk
Tried that, just barely slipped off. Thanks though.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Mine is 17mm.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 294 times
Been thanked: 767 times
Post by erikv11 »
For the record I like to use a box wrench for this (yes, 17 mm). I am more likely to over-torque it when I am reaching back there with a socket on a ratchet. The box wrench doesn't give you as much leverage, I get better control over the tightening. It just needs to be snug,you don't want to strip out the pan threads.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Pauloil
Post by Pauloil »
use a 6 sided 17!
99 V70XC 158K
95 850glt 188K
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Amen to the 6 sided socket. Too many drain plugs have had the heads stripped off using 12 point sockets or 12 pt box end wrenches.
Sim
