We are second owner so don't have history on age of coolant.
I did notice that the screws retaining the thermostat housing had already been changed to coated steel screws (Torx 40) which I gather were not original on this year or ?
Only thing that worried me a bit was tightening the ECT sensor. The 19mm combination wrench which I used supplies a lot of torque in my hands and I hope I didn't start to twist it off. i.e. It is hard to judge how much force is needed to crush the aluminum washer to ensure a leak free installation without twisting off the thin brass ECT sensor.....
The coolant was an opaque greenish colour. i.e. obviously had deteriorated to some degree....
Probably needs to be changed.
Is it best to use the Volvo antifreeze or are other types ok also? If so, what other types. And I guess it best to never mix different types?
