Wire conection for hand remote starter
MA Volvo
Year and Model: 850 1997
Post by MA Volvo »
I would like to know the proper location to connect the 2 alligator clips for my push button remote starter on my 95 850. I have a no-start condition that I am trying to diagnosis. I want to ground out the spark plugs to determine if I have a spark. I have gas in the fuel rail (opened the schrader valve) and I presume I have good compression.
I did this procedure years ago o my 760 and 240s.
I connected to the 2 lugs on the starter solenoid. The front lug has a thick red wire and the rear lug has a thick white wire. However, when I did this I only heard a faint "whirl" sound" when I pressed the remote started button whether the key was out of the ignition switch or when is key was in and turned to the accesory position.
1997 850 turbo - 180K
Past: 96 - 940 grey; 98-V70 black; 89-760 turbo wagon blue; 87- 760 turbo white, 85- 760 turbo grey - manual; 84-245 brown; 79-240 green manual
Has thanked: 294 times
Been thanked: 767 times
Post by erikv11 »
Check out post #6 in this thread, this might be what you are looking for:
https://www.matthewsvolvosite.com/forums ... =1&t=41566
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
