2000 S80 T6 Purge Valve Hose Routing Photos Plz :'(
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Mig23xxx
Year and Model: 200
Post by Mig23xxx »
Hello , First time poster here . I Finaly ran into an issue that I could not figure out.
Background: Since I bought the car there has been a constant random Tapping noise coming from the bottom of the car I thought It was a cracked exhaust pipe or something. Until I decided to finaly fix it today.
Turns out it was a hose that comes from the Purge valve and follows the fuel line. It was cut and was making the sound .
My issue is I cannot find where it paths to . I know it goes connects to the Canister that box under the trunk area. The Canister does actually have the hose connected to it but I am only able to follow it untill it goes avobe the gas tank , I was trying to follow it untill i saw where it was chopped off at but I could not.Unless I was looking at the wrong side of the cannister, Note: I was folloing the hose in the Driver side from the cannister I dont know if that was the correct hose to follow.
If anyone has time or is working in that section and could please post pictures of the hose and where it leads to. I would be very happy .Yes the Check engine light is on with Major evap leak :)
Here is a picture just incase I didnt make myself to clear. Image
The picture is from just bellow where the passenger would sit.The huge oil leak is also another thing im working on seems to be coming from the rear cam housing side.
Thanks for the help.
Eldoninoz
Year and Model: S80 1999
Post by Eldoninoz »
Don't know if this will help you but there is a diagram here diagram in this previous thread shows the routing of the emissions system. Hope this can help.
Mig23xxx
Year and Model: 200
Post by Mig23xxx »
Ya ive seen that. Its bothering me bc its making the noise, I can probably plug it but I think that will raise the presure somewhere. I think if i cant find where it should lead to I will just add a crackcase filter on it so It can reduce the sound it makes .
Thanks.
Mig23xxx
Year and Model: 200
Post by Mig23xxx »
Anyone ?
