Rear Brake Light failure 2001 s60
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Brad Colyer
Year and Model: 2001 volvo s60
Post by Brad Colyer »
Rear brakes lights are not working, the third brake light is, I have checked and changed the fuses and the bulbs still a NO GO, any help would be great, I pulled up the schematic which was funny because I can't read one..lol :cry:
Thanks, :?
Brad
cottonwood2
Year and Model: s60 2001
Post by cottonwood2 »
I've get same trouble, I didn't solve it yet. I went to dealer to diagnost it and they said could be related with failure of alarm siren. Thanks guys from forum I ordered the part and probably I will change myself the siren, and I will see what happened.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Did you check fuses in the rear electric module in left quarter panel?
If the fuse is good there then put a stick between seat and brake pedal to keep brake light on and wiggle and push gently on the black strips you will see plugged on the right side of the REM unit. Those black strips are how the bulbs are checked for the bulb failure system. Some times the strips (shunts) can be loose and they do fail and can be replaced.
The third brake light is not powered through the REM.
cottonwood2
It is a good start! I checked fuses are OK, I checked these strips if they are ok in place and looks ok for me. Thanks jimmy.
    DGM
    Year and Model: V70 2.4i 2005
    Been thanked: 3 times
    Post by DGM »
    The circuit diagram can be found on page 49 (PDF) of the following document.
    https://www.matthewsvolvosite.com/downloads/2001_S60.pdf
    First I would suggest to verify again fuse 11D/3 in the cargo compartment (Page 24 ). Then verify if the relay 2/79 in position RM15 is well inserted. Do you hear or feel the relay clicking when the brake pedal is applied. Use a long screwdriver that you hold on the casing and the other end to your ear. You can substitute the relay with another one to test it.
    If it is clicking, look if you have battery voltage coming to the relay socket from the above mentionned fuse. Then if you have voltage, you can use the electrical plug 54/51 (the factory hitch plug /page 155) as a test point to see if you have voltage on the other end of the relay (pin 4 of the plug/ yellow wire). It is a good idea to detach your trailer harness during testing if you have one installed (it can be the source of the problem).
    Also verify the shunt in position RSH6 as Jimmy mentioned.
    The grounding points of the light assemblies are different then it shouldn't the problem.
    Other than this it could be a "special cause" above the average skill of a DIY.
    V70 2005 2.4i 195,000km, sold
    S70 1998 T5 355,000km, sold
    960 1994 80,000km, sold
    760 1990 Turbo 265,000km, sold
    cottonwood2
    The relay was gone. I changed it, and now the lights are working.Thank you guys.
    98T5
    Year and Model: V70T5,98' / 940,93'
    Post by 98T5 »
    Take small cuts of cardboard and sandwich them together and put them in between the offending relay to keep it tight and snug in there. I had the same problem and that's what I did. no more "Check Brake Light" headaches.
    98’ S70 T5 Turbo Manual - Midnight
    01' S60 T5 Turbo- Brandy
    98' V70 T5 Turbo - Swifty
    93’ 244 n/a - Mr.Chill
    91' 940 SE Turbo - Mojo SOLD
    83' 242 DL - Bluto SOLD
    93' 940 Wagon - Django - SOLD
    :mrgreen: 8) :mrgreen:
    Has thanked: 1497 times
    Been thanked: 3810 times
    I had to clean the fuse contact on my P2 in the left rear quarter panel fuse rack. Wierd failure.
    I think I wrote a quick thread on it
