98 s90 a/c problems Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jstick302
98 s90 a/c problems
Post by jstick302 »
the a/c is not working on my 98 s90 ,the system has a full charge of 2.07lbs and I have checked the known solder points on the climate control board for cracks , the compressor will come on at start up for a second and then shuts off, I have cleaned the interior sensor in the dome light fixture and changed the pressure switch just outside the firewall ,does anyone else know what needs to checked or tested , there are 0 volts at the compressor after it shuts back off after start up.
