Axle replacement
VolvoMonkey
Year and Model: V70 XC 1999
Post by VolvoMonkey »
I've seen recommendations for raxles.com but they don't currently have an axle I can use right now. My front right CV joint is leaking and I'm starting to get clunking/ticking noises when making tight turns. So, I need to replace that axle. I'm driving a 1999 V70 XC
Any suggestions on brands?
JDS60R
Been thanked: 3 times
Post by JDS60R »
OEM (Volvo) is my fallback position when Marty (Raxles)doesn't have one. Most of the local brand axles have not done well. If you are just waiting for Raxles to have it in stock a junkyard axle might get you through for a while.
Retired
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Call up Axles Unlimited. I got my replacements from them (for the same reason as you, Raxles doesn't make XC) and have been very happy for tens of thousands of miles.
http://www.axlesunlimitedinc.com/
2000 V70XC - 340,000 miles
2023 V60 T8 PE
VolvoMonkey
Thanks for the suggestion. I sent them an email.
mobiledan
Year and Model: 98 Black V70R
Post by mobiledan »
I talked to marty... What I gathered was that when people were returning their cores, they were giving him their failed Chinese ones that they gave their original Volvo back as a core... Ensure you actually have Volvo axles and send them to him. 2-3 days ground... Next day turn around and same 2-3 days ground back... Car will be up on blocks for a week vs. Changing with Chinese part and doing again the following year... If its bad enough 1 week of driving wifes car or renting will be worth it...
I haven't used him before, but am doing just that... Both sides.are shot!
chris81964
Year and Model: S60 2001
Post by chris81964 »
I bought right side axle from FCP. Over 500 miles later it still works fine.
