Hey guys,
Is the temperature sensor on the XC90 located under the dash above the gas pedal? I changed it out on my v70 and I'm assuming it is in the same place but you know what they say about assuming...
2006 xc90 temp sensor location
whaleplane
- Year and Model: 2014 S60 T5
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Do you mean Engine Coolant Temp Sensor, (Volvo) part # 8627679? This part is located at the thermostat housing. If you are speaking of interior climate temp sensor, I dunno.
98 S70 T5-M Brick for life
whaleplane
Thanks for the help.
Jimmy57 that's what I'm looking for. Starting to see some of the same symptoms in my xc90 that I saw in my v70.
If you've broken the sensor behind the three slots, how do you repair it?adki110 wrote:The cabin temp sensor (A/C-heat) is behind three slots over the passenger temp knob, do not go poking around through the slots, the sensor is a thermistor that is very easily broken.
adki110
- Year and Model: XC90 2006
"If you've broken the sensor behind the three slots, how do you repair it"
When mine was broken I bought a climate control module from e-bay and soldered the thermister from that on onto mine. Unfortunatly I did not think to measure the resistence of the thermister or check to see if it was a negitive or positive co-efficent type.
good luck
good luck
