Engine Replacement 2.5t
bumgardner
Year and Model: XC90 2004
Post by bumgardner »
So I just talked to my mechanic. The news is not good. My wife's Volvo XC90 2.5t AWD is in need of a new engine. It has 144k miles on the clock right now. It is using about a quart of oil ever 1k miles. The oil is collecting in the lower end of the engine. My mechanic said that it would not be worth rebuilding the engine...
Any thoughts on a replacement engine?
gshadow325
Post by gshadow325 »
this info seems very very vague. why does it need a new engine? 5 cylinder engines are the staple platform that is used in almost every line up volvo has.
thoughts are get a second opinion.
1998 Olive Green V70 T5 Manual - 155k Awesome car
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded
2001 Nautic Blue C70 T5 Manual - 92k Not stock at all
bumgardner
About all I know is that he said, that a lot of oil is getting though the piston o-rings.
Does that help?
adki110
Year and Model: XC90 2006
Post by adki110 »
Not enough information, is it throwing codes, running poorly. Could be as simple as a clogged PVC system. Get another opinion from a mechanic that knows Volvos.
bumgardner
I am getting a second opinion from a Volvo certified tech. The mechanic that I use is certified on other makes, but has not worked on many Volvos.
My mechanic checked the PCV. I have never heard of a PVC what is that?
The mechanic checked the PCV system, coolant, turbo, spark plugs, oil pan, etc trying to figure out where the oil is going.
adki110
Post by adki110 »
Sorry, I miss-typed PCV not PVC
ed7
Year and Model: V70XC 2005, 2001
Has thanked: 2 times
Post by ed7 »
Positive Crankcase Ventilation System being clogged is the likely problem at that mileage.
Search the archives for more info and photos.
Ed
bumgardner
As I said we already checked the PCV system. So that is out.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
This doesnt add up, on one hand I am reading busted rings, on another Im reading external oil buildup. Can you get pics of the oil buildup? Its possible the rings are shot, sure. But is really, really, realllllly rare unless oil changes have been missed. What method was used to check the PCV and give it a clean bill of health?
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
bumgardner
I'm out of town till next Wednesday. I will take things apart again next Saturday and post up the pictures. When I took it apart before taking the car to the mechanic it looked like the PCV system might have had a clog, because I saw some oil that had been dripping/leaking/coming out of part of the PCV system (can't remember what part at the moment I don't have the schematic in front of me). But, when I took it to the mechanic he said that was normal for the PCV system to have a little oil leaking out... I'm unsure of how he tested the PCV system to determine that it was ok.
