Oil cooler leaking around connection to oil pan
I was wandering if there is a gasket that is behind the oil cooler that would cause it to leak? thanks
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
There is something which they call a 'Cable harness' but to me it looks more like a seal.
I have attached .pdf files from VADIS which shows the parts list and the parts drawings (exploded).
Hope this helps. Let us know what you find if you take it apart....
2002 S80 oil cooling parts drawing.pdf- (66.23 KiB) Downloaded 254 times
2002 S80 oil cooling parts list.pdf- (30.26 KiB) Downloaded 387 times
