All the sudden my 1997 850 GLT wont start and the dash lights stay on for about 3 minutes after removing the keys. The fuel and fuel relay is fine, I checked by depressing the valve under the blue cover on the fuel rail. I also there is no spark at the spark plug, but the ignition coil and distributor is in working condition. The car cranks but wont start. I'm thinking its something to do with the anti-theft system. I tried locking and unlocking the car five times but still would not start. Anyone experience a problem like this or have advise what to check.
Thanks
Help: No Start/Dashlights on after key removed
turbos70t5
- Year and Model: S70 1998
1998 Volvo S70 T5 - Present
1997 Volvo 850 GLT- Present
1986 Volvo 240 DL Wagon - Sold
1986 Volvo 240 DL Sedan - Sold
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Sounds more like the electrical part of the ignition switch
may have reached "the end of it's broadcast day"...
The good news? Cheap part, easy swap.
turbos70t5
Do you think the ignition switch can cause the OBD2 code reader port not to work also? I tried to read the check engine light code but got an error message. I know the code reader works because I tried it on my other Volvo. I also checked the #15 fuse and its fine too.
- 11 Replies
- 7990 Views
Last post by Ringo
- 604 Views
Last post by JimBee
- 4277 Views
- 20 Replies
- 3857 Views
Last post by RickHaleParker
- 13 Replies
- 6602 Views
