Catalytic Convertor
jamestkirk
Year and Model: V70, 1998
Catalytic Convertor
Post by jamestkirk »
:?: I have a '98 V-70 (132K) and need to replace the catalytic convertor ( check engine light is going off because of it). It's still in good shape, but would like to get people's opinion: buy a Volvo convertor or after-market?
broke wagon
Year and Model: 240DL wagon 90
Post by broke wagon »
Dam it Jim... what would Mr. Scott say??? Where's an engineer when you need him... Go with the aftermarket from ipd :)
jamestkirk
Cool, thanks, but why after market?
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Price, mostly. Some Volvo parts should remain true Volvo spec's (Bosch O2 sensors, for example) but some things can be aftermarket. For a cat, I'm sure you could go with anything that'll fit under there and has a hole for a rear O2 sensor. Since you're not in California, you can pretty much go with anything.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
jamestkirk
V, that's interesting because I just had both 02's replaced with after markets and still have the check engine light on. My mechanic said this time it's the cat. coming up on the code. He reccomended not going with after market as it sometimes won't clear the code. Maybe he should have said that for the O2's. :? :x
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
ox sensors should be volvo and cat should be aftermarket. I think your mechanic is shooting for fish in a barrel.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I would disagree with that in most circumstances
Most people have not had good luck with A/M converters
Try calling Erie
http://www.erievovo.com or 1888 volvo 13
They should have some used ones and...they guarantee them FOR LIFE, so if it goes bad in 6 mo, a year or whenever, they will replace it.
They charge about $300 or so for a used CAT
vjaneczko
Post by vjaneczko »
JRL wrote:Most people have not had good luck with A/M converters
Hmm, now I'm a bit nervous - I just installed the IPD turbo back kit which includes a racing cat. I picked up two new O2 sensors so I'll keep you posted if I run into any CEL's from the setup.
2006 S60R - For ME!
JRL
Post by JRL »
Well it would have been better if you said that in the first place.
Now you know where to turn...
First, remove those 02 sensors and buy Volvo 02 sensors.
Sometimes Bosch can work, depending from car to car but any other brand usually does not.
If that doesn't work go back to IPD, but I'll bet those sensors don't work in this car especially with an aftermarket CAT
