C70 into 850T valve swap
lumberjackzac
Year and Model: 855T '96
Post by lumberjackzac »
Greetings,
I've been planning and waiting on this engine swap project for about a year. A nice price has come by and I understand that some of the 98 C/S70's have variable valve timing, VVT. My question is simple and refined.
If you swap the valve-train from an '96 850 turbo b5234T5 (bad compression) to a 98' C70 B5234T4 /T5 /T3 you should basically have an engine that will run on the 850's ECU no problems? Right?
Or is this madness?
:shock:
96' Batmobile Volvo 855T Auto - 97,586* deer impact *
Purring nicely. Fan issue still keeping it off the streets
96' Burgundy Volvo 854 Auto - 225,000 - Junkyard $125
Donor car for most my parts needs now. lol
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The valves are all the same between the two. You might get into trouble if you try to just swap the heads if one has CVVT and the other one doesn't - I'm not sure. The original cam sprockets are a must since they have different timing marks and the exhaust cam sprocket is a totally different animal. The 850 ECU should deal with it just fine but the inverse (850 valve train into a CVVT car) will be grief forever.
When I get back home I can look some stuff up for you on VADIS to try to figure out campatability on the head and the cam cover but that will be Saturday at least.
h20ham
Year and Model: 1998 xc
Post by h20ham »
Anyone know if the cvvt head fits. How bout the cams?
Thanks!
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
