buying a standard wheel bolt for 1998 s70
BlackJack
Year and Model: s70 1998
Post by BlackJack »
I can't seem to find anyone on ebay that is sells a standard wheel bolt that will fit the original steel wheels of a 1998 volvo s70 as they are all bolts for alloy wheels which are the thinner ones, none of my local garages have any.
Can someone point me in the right direction?
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Welcome to the forum!
Explain "thinner ones" - they should be the same since they bolt into the same hub, right?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Yeah, I think so too - the hub bearings are the same for all of the cars regardless of what wheels you have on the car.
'98 S70 T5
2016 Chevy Cruze Premier
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Old school aftermarket alloys used deep shouldered bolts or nuts with the same arrangement. Volvo alloys use the same bolts as steel wheels.
BlackJack
Post by BlackJack »
Ok well i have been given bad advice then as I ordered a set of bolts for alloy wheels for the s70 but when they arrived the head was much smaller then the ones already on the wheel and was told they won't fit and I don't have alloys on my car, i have steel wheels, the original ones.
Look at both these links
http://www.ebay.co.uk/itm/Volvo-Wheel-B ... 2c55158055
and
http://www.ebay.co.uk/itm/VOLVO-FIT-WHE ... 3ca350040c
They both say bolts for volvo s70 but they different lengths so what will fit the original steel wheels?
egads
Year and Model: S70 98 XC90 08 C40
Post by egads »
The first ones look to be the right length. As has been said, same bolts alloys or not except you can get ones with a bigger head to make putting them on some alloys easier.
precopster
The ad with the longer bolt in the pic states that the thread length is 28mm, therefore they have a picture which is grossly incorrect because the pic shows a bolt which has a thread length of at least 55-60mm. Remember 28mm is just over 1.25 inches.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If you mean STEEL wheels, not "standard", they're the same as the alloy wheel stud/lug bolts
BlackJack
Post by BlackJack »
JRL wrote:If you mean STEEL wheels, not "standard", they're the same as the alloy wheel stud/lug bolts
hey mate i did say steel wheels in my posts thats why I keep telling people I don't have alloys! have ordered a single bolt so going by what people are saying its impossible to order the wrong bolt aslong as the person selling is selling me a s70 bolt.
curtismc56
Year and Model: S70 1998
Post by curtismc56 »
What year's and model's will fit my 98 S70. I currently have 5 spoke alloy wheels. Got a nasty curb burn that makes the tire shop cringe!
