Amplifier 50W
nicopag
Year and Model: v70 2.5T, 1999
Post by nicopag »
Hi, today I fix my amplifier. It has one channel that sounds like wind and horrible noise. The problem was one of the ICs.
The model is TDA 1514A
Just that
Good luck
V70 2.5T, L.H.D /S.R, 1999
jmmxc
Year and Model: Volvo 850, 1996
Post by jmmxc »
This is the output power amplifier IC (in case you do not know..).
Spec can be found here:http://www.datasheetcatalog.org/datasheet/philips/TDA1514.pdf
What was the problem?
Any problem with your speaker wire cable, any short in the wiring. Usually it is either too much heat that blows these modules.
By the way have you noticed any thermal grease (or lack thereof) on the heatsink assembly.
Did you have to replace or do some resolder?
jmmxc
nicopag
Post by nicopag »
Hi jmmxc! Thanks for your information. The problem was only the TDA 1514A. I replaced it and now it works.
This IC was affecting me the rear left speaker and rear rear left twitter. Now I have my 8 speakers working
Yoni
Year and Model: 96' 854T 93' 940
Post by Yoni »
Thanks!
Chrome Does'nt like that link : But it does like this one : www.datasheetcatalog.org/datasheet/philips/TDA1514.pdf
owgz35
Year and Model: V50&2010
Post by owgz35 »
50 watts is a lot of power for a tube amp, my guitarist has a 15 watt tube amp and is heard over a loud drummer a 200 watt bass amp and another 65 watt guitar amp. I think its good to have the most power as possible so you don't need to upgrade anytime soon. I think that you will get tube warmth at a low volume not necessarily overdrive but thats what the gain is for right?
nicopag
Post by nicopag »
Does anybody know the model of the other chip. I mean the mofset.
I dont want to open again the amp to watch that.
if anybody knows, please let me know
thanks
nicopag
Post by nicopag »
I openned the Amp and the Mofset is BUK456-60H
