Strange Noise when Turning
turbotim2
Post by turbotim2 »
This is going to be difficult to explain but here goes! Recently my 96 850 wagon makes a strange noise when I am turning to the left and at slow speeds. I notice it when I am at a light and making a left turn for example. The noise is like a resonance, a low pitched whirring noise. At first I wasn't even sure it was my car but it is. Any ideas? The strangest thing about this is two days ago my wife and I test drove a 98 XC and this car made the same noise except all the time, turning or not. After the test drive, mine started doing it! We really liked that other car too, if its something minor I will consider getting it (and fix the 850). Thanks for any help and Happy Independance Day!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
White850Turbo
Post by White850Turbo »
Sounds like a wheel bearing to me, probably the right when since it happens when you turn left. Check out all of your steering and axle components while you're down there though including tie rod ends, cv boot, etc.
-Sean
1998 S70 T5 (Almost Stock)
Guest
Post by Guest »
OK, thanks for the input. I drove the car all weekend and it hasn't really been making the noise again. I will post what I find.
larry_bad_boy
Post by larry_bad_boy »
just put som greace a the well stoper on both side
turn the whell complet att the and and you see were to put som grease
it apen to me to
Guest
Post by Guest »
I don't understand what you are trying to write...
White850Turbo
Anonymous wrote:I don't understand what you are trying to write...
I believe he's trying to say to grease the steering stops, but ungreased steering stops make more of a creaking sound.
-Sean
Guest
Post by Guest »
Oh ok, thanks. Yea, I don't turn the wheel all the way to the stops so I doubt that is it. I am actually having a tough time now determining whether it is in the front or rear now. The more I listen, the more it sounds like rear.
turbotim2
Post by turbotim2 »
Just a follow up, the bearings all seem to be good on the car. What I have found is that even with the car sitting still and off, I can get this noise from it by bouncing the car a bit. It seems to be coming from the rear right side. Maybe a squeaking shock or spring? Sound familiar to anyone?
2004 XC70
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
From your last post it sounds like you spring seats/shock mounts to me.
https://www.matthewsvolvosite.com/spring_seats.php
Usually these tend to make a creaking/groaning sound.
Also -> Amazon link
HyperOskar
Post by HyperOskar »
Hi , we have the same phenomenon on our 855 AWD -97 .. the explainations I
VOLVO RACING - SWEDEN
