New CD player, need help 95' 940
Chris940
I bought a new cd player, a legacy, and took the old radio out, the wires obviously don't match and i need an adapter or a wiring diagram, can anybody help or point me in the right direction?
If you visit your Volvo dealer or car audio expert, you will probably find an adapter fitting your new CD-player and also fitting the Volvo. Different CD manufactures uses different std connections, but my guess is that it does exists 3 or 4 different connections for the CD player in the world and for those you can buy an adapter.
Anyway, if you want to cut the wires, here you have the colours:
Right rear - /GN-SB , right rear + / Y-SB, Right front - / GR, Right front + / Y-GR, Left front + / Y-W left front - / W, Leftr rear + / Y-BN Left rear-/ GN-BN.
Ground / SB, battery +, P-SP, both wires.
Then i is one more connector with discant right +/ GR-R, discant right -/ GR, discant left - / R-W, discant left +/ W,
ACC+/ Y-SB, ground/ SB, Batt +/ GN-BN , reostat +/BN-SB, reostat -/Y-W with a V-W jumper to dimmer
