When I pull the key out of the ignition, the dome light(s) should turn on. As of about 2 weeks ago, I noticed when I pulled the key out, the lights flicked on and off and the doors locked. Thought it may have been a fluke, but it's been doing it a lot more frequently. During the summer, the chime also stayed on a few times while driving until I got where I was going and pulled the key out. Jiggling it did nothing. Which reminds me of another symptom; When I turn on the engine, the lights/HVAC blower/etc do not work until i twist the key back slightly.
What part am I looking at replacing?
I used to be able to turn the key to the off position and keep rotating a few years ago...some reason that stopped.
Thanks,
Chris
edit: it's a 1998
S70 t5 odd problem...
cjbmustang
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Ignition switch, this happens to 960's all the time.
http://volvoforums.com/forum/volvo-260- ... ues-56256/
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Hmm, it sounds like both parts of the ignition switch are going. The key spinning around is the mechanical part (tumbler/steering lock); the having to twitch the key, etc for the electrical stuff is the electrical portion of the ignition to the left of the steering column/
A bit of graphite lock spray and putting the key in and out of the ignition can free up the little tab inside that keeps the key in or turns the lights on/off if you don't want to yet take on the problem of replacing the whole tumbler if the key isn't spinning around in place.
'98 S70 T5
2016 Chevy Cruze Premier
cjbmustang
i guess things are bound to go after 300K miles...
thanks guys
thanks guys
cjbmustang
I'm now in a parking lot and my key will not turn past the first notch on the ignition. If I take the column apart is there anyway to bypass this? Or is the tumbler the culprit? P.s. I'm angry.
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new ignition lock/cylinder
If you want the same key as the doors you need to order it from Volvo, they are made in Sweden and sent.
Takes about a week to 10 days and at retail not that cheap.
Sort of a messy hour or so job, you have to drill out the old lock, (very carefully)
cjbmustang
i hit the ignition lock with a socket wrench and it works. i sprayed some graphite lubricant in there also. seems smooth. can't wait for it to do it again! (sarcasm)
cjbmustang
i take it i want this part?
http://www.volvopartswebstore.com/produ ... rm=8626325
Lock cylinder set
column lock. For this part number the lock cylinder will be delivered with ordered combination, but with no key.
how do i figure out the order combination?
Lock cylinder set
- rspi
Contact rspi..
Sounds like you need more than one part buy I would try this one first and go from there:
http://www.fcpgroton.com/product-exec/p ... ory_id/199
Your local dealer can provide the combo on the lock - via the VIN number (providing no one has changed them before...) I an S70 and V70 that had those symptoms, a little graphite spray fixed both of them. The tumbler being sticky can cause the switch to not return to the ON position and hence the need to 'jiggle' it. The trick is to use a little, I spray the key and give the lock a shot, then do the funky with the key a few times to mix it up good.... Usually works and is a whole lot less $$
- 11 Replies
- 3206 Views
Last post by marwood82
- 3622 Views
Last post by erikv11
- 442 Views
Last post by DeluxeRaccoon
- 1464 Views
Last post by oragex
- 39 Replies
- 2929 Views
Last post by VolvoOwl98
