2000 S-70 electric window
The drivers side electric power window will not raise on my 2000 model S70 Volvo when the button is activated (pulled up), when the button is pushed down I hear a small click like noise. All of the other windows work properly. How do I go about removing the door panel to gain access to the power window button wiring inside the door panel. Any help in this matter is greatly appreciated. Thank You.
hi,
I guess www.volvospeed.com has the procedure to remove the door panel. when you go to the site click on "reapirs/Maintenance" there you should see the link for door panel removal
ihsan
ihsan
dpauto.com
- Year and Model:
Sounds like you have a bad window switch. You have to replace the whole assembly. (Common problem)
But of course, without seeing it.....I am just guessing!
Dave
Dave
ASE - VOLVO Master Technician
- 706 Views
Last post by E Showell
- 11 Replies
- 3143 Views
- 1019 Views
Last post by difflock54
- 369 Views
Last post by BEJinFbk
- 4924 Views
Last post by dcm0123
