1999 S80 T6: $1224 for steering rack and labor
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
This is all 2nd-hand info from my dad (it's his S80) on the phone. It's got perhaps 120k miles on it.
He took it to Firestone to get a rotate and balance. Pulling left after alignment. Not pulling before alignment. They say it's the rack.
Complete rack assembly, RMF $734 (parts and labor)
Remove and replace crossmember $490 (parts and labor)
$1224 Total.
Good? Bad? Keep looking?
Thanks in advance.
Also -> Amazon link
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
Run away. That place is a rip off. My dad took his car there for tires and they told him he needed ball joints and tie rods. He said ok, took his car to a guy that has been doing our alignments for years. My dad told the guy what he said and he checked it. The guy comes back and said he could use one new tie rod, but the other was fine. The ball joints were ok and one had even been replaced (other was original). Guy told my dad they flat out lied to him. Screw that place.
Sent from my BlackBerry 9810 using Tapatalk
Choguy03
Post by Choguy03 »
By the way, what did they screw up? If it was fine before and now not after and would tell them it was something they did.
matthew1
Site Admin
Post by matthew1 »
I purposely didn't mention the word "sabotage" as to not trigger that aspect first, to see if it would come up naturally. And you alluded to it. That makes both of us suspicious.
That's what I told him on the phone (sabotage). He's clueless about cars. Thanks for the reply, Choguy.
Also -> Amazon link
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Run away!
I went to firestone for a $49 A/C test and brought my $10 coupon. They charged me $49 ($10?!?) to tell me the A/C didn't work and then gave me an estimate of $384 so they could test the A/C system and tell me what's wrong. Then they would give me an estimate to fix it.
So it cost me $50 to find out it was going to cost me $400 bucks to find out how much it was going to cost me to fix it.
W T F !?!?!?!!
Oh, and they said that they had to test my fan system because it was the malfunctioning problem.
Well.......ten minutes on MVS and one bread clip later and I am writing an angry letter from my nice air conditioned car.
If they would have said "your charge level is fine but you need an A/C clutch and it will cost $xxx" I would not have minded. I might have even given them my business. Instead, the free oil change coupon they sent with my refund check and apology letter went straight into the trash. So I, personally, don't trust them.
But, thats not a bad price for a rack replacement. Mine cost $1700 at the dealer.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
bronxnativ
Year and Model: 96 850 GLT 5 Speed
Post by bronxnativ »
Matt,
$600-$700 is the average rate here in Denver for a Rack and labor. I shopped about four local indies last year when I needed it replaced on my 95. As far as Firestone is concerned: looks like you figured it out.
Al
jimmy57
Been thanked: 320 times
Post by jimmy57 »
They should rotate tires and re-check for pull to eliminate tire pull as the cause.
Rack can cause this but is it usually the immediate result of a hard curb hit that tweaks the torsion bar in proportioning valve in upper rack.
OH, the print out for alignment should show small TOE-OUT, not toe-in if they are suing the correct latest specs from Volvo. Toe-in on P2's can cause pull.
matthew1
Site Admin
Post by matthew1 »
Thanks Jimmy, Al, Fazool. Jimmy, I printed out* your toe in/out sentences to give to my dad so he can go back to them with something from a (ex?) Volvo tech.
I got a quote from my friends at Volvo Specialists down the street from me, and yes, it was less than Firestone's.
* For those of you who need to print out pages, look for this Image in the upper-right of topics. It takes you to a "plain" version of the topic, suitable for printing.
Also -> Amazon link
J5T
Post by J5T »
One issue that I have come across (besides never trusting Firestone) is that some alignment places have a hard time finding when the bushing are bad in the lower control arm. Switching the tires may have cause the pull but putting them back should fix it (meaning the pull, not the actual cause of the problem). My feel from reading your post is that your dad needs not a rack. It would have been dong this no matter what tires were on the car. Always get another opinion. Glück!
Macht's Gut!
matthew1
Site Admin
Post by matthew1 »
So it turns out (no pun intended) the rack is not a problem, not broken, and no work involving it is needed. I'll let you draw your own conclusions from that.
The tire rotation put the tires in a configuration that caused the pull. My dad bought 4 new tires yesterday -- not from Firestone -- and the pulling is gone, problem solved.
Thanks for everybody's input.
Also -> Amazon link
