91 740 steering is really hard
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello everyone,
I got my 740 running now after sitting a year or so...
The steering wheel is really hard, it is almost impossible to turn wheels when stop and really hard to turn when driving slow.
I checked the fluid and it is fine, didn't see any leaks, belts look fine, everything seems like working but something is wrong..
Anybody has an idea?
Thanks in advance...
Nuttydriver
Year and Model: 1998 v70 xc
Post by Nuttydriver »
Pull your serpentine belt and see how easily the power steering pump spins. It sounds like it's not pumping to me.
Vehicles:
98 Volvo v70xc
99 dodge Dakota
81 chevy chevette
89 chevy k1500
neworleans
thanks for your reply but i never dealt with belts, can you pls somehow show me how to remove serpentine belt?
Kirby J
Year and Model: 99 v70, 93 940
Post by Kirby J »
you might also check the ball joints on this car. It is an easy repair, and will affect steering effort if they are bad.
Kirby J
93 940, 426K miles
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Nuttydriver wrote:Pull your serpentine belt and see how easily the power steering pump spins. It sounds like it's not pumping to me.
A 740 uses V-belts, not serpentine. A slipping crank pulley (harmonic balancer) can cause power steering symptoms.
1988 Volvo 760 Turbo Wagon
LamboSE5
Year and Model: Empty
Post by LamboSE5 »
That sentence worries me. Would that be the same with a '98 S70 T5 SE? The steering is really hard at startup, requiring two hands to turn the wheel. Once turned from lock to lock about 3-5 times, it's "fairly" normal....i.e.: loosens up significantly.
