Air conditioner and acceleration
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Lin
Post by Lin »
We just got a 1997 S90 with climate control. I find that even during normal acceleration the A/C seems to shut down. I know that the fan does for sure. What needs to be done? Thanks, Lin
Kmaniac in California USA
Post by Kmaniac in California USA »
Are you absolutely sure the blower fan motor is shutting off completely? Manually set it to the highest setting the next time you drive to be sure. I suspect your ventilation dampers are redirecting to defrost mode with the loss of engine vacuum under acceleration.
Please do a forum search on keyword "kmaniac" and read my posts on this subject. Then take a look again at your car and let us know what you find.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
Lin
Post by Lin »
Sounds like a good possibility. I once had a 1983 Mercury with climate control that would default to defrost with heat when vacume failed. That turned out to be a few bad lines and faulty check valve. I would be happy to find it is the same thing here. Tomorrow I will see if the defrost is going on. Thanks
