I'm totally stumped
The back story is that this 1997 NA has been throwing a CEL for over a year (5th Cyl low/ almost no compression and I've just been living with it) Emissions is coming up though. Anyway my MAF sensor went bad and after I swapped it out I inadvertently hooked the white and black vacuum lines on the aibox in reverse. I reconnected the battery, started it up, and bang, Magically the CEL was gone. Drove it around for three days. No codes no CEL. However, I stated getting the "smokestack from the dipstick tube. (Didn't do it prior) So I just figured it was coincidental and it was just the PCV clogged. So I was about to take it through emissions, and gave it the once over, thats when I noticed, I had the white on top and Black on the bottom. No biggie right? Swapped them correctly and BAM!!!! CEL came on. So now I'm contemplating disconnecting the Battery and swapping them back to the "wrong way" in hopes it will magically clear until I can get it through emissions. Any thoughts? I don't see how the ECU could not have reset since I drove it for 3 days with those lines transverse. And with in 10 seconds of hooking them up correctly the engine quieted a little, the sound changed to it's "normal self" and the CEL came right up. At this point I'm baffled and could really use some input.
- Has thanked: 311 times
- Been thanked: 817 times
What vacuum lines are you talking about? A picture would help a lot.
I am confused by your post. At the beginning it says reversing the lines eliminated the code, as if it fixed the problem. But then at the end it says switching the lines back made it run better. At any rate, I'd be very surprised if vacuum lines were related to compression in #5.
What is the code for the CEL, p0305? Gotta know the code. Did you measure compression, is that why you say it is low? Does #5 fire at all?
- 2801 Views
Last post by famfeld
- 23 Replies
- 4292 Views
Last post by vtl
- 1032 Views
Last post by TisMe
- 661 Views
Last post by Krons
- 1221 Views
Last post by dgcantrellsr
