Transmission Fluid
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Transmission Fluid
Post by chrism »
Yesterday I had to replace the radiator in my wife's 2005 S80 2.5T. I lost about 1 cup max of trans fluid when I disconnected the trans coolant lines from the radiator. I also noticed it was looking pretty dark. I would like to flush the fluid and bring it back to proper level, but where there is normally a small dip stick (like on my 2003 V70) all there is is a short section of small diameter rubber hose attached which is capped on the top. I'm 99% certain that's the way it came out of the factory. How does a person service these transmissions?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The dipstick/fill tube is hiding under the lower rad hose on front of trans. Move the hose to the side and you'll find it.
quietlymknnoise
Year and Model: s80 2006
Post by quietlymknnoise »
If you replace the fluid via the top hose, the fluid will pump out from the radiator's connection not the hose. The hose sent with IPD's kit will fit inside the connector and can be held there or duct taped. The IPD kit has everything you need. I got my fluid at Toyota. Their Type VI fluid is the same as Volvo's or Mobil 3309. They use the A/W transmission in some of their autos.
chrism
Post by chrism »
I'll take another look for the dipstick under the rad hose. For fluid, I've ordered Mobil 3309 from a place called AV Lubricants ~ $65/case + $18 shipping. That beats what the local Toyota dealer wanted. I didn't even ask the local Volvo dealer for obvious reasons.
