Hello.
My car leaks several oil drops a day when parked. I suspected the turbo return line. From the bottom of the engine, I observed that the two screw area for the driver turbo return line was clean (no leak). I was not able to observe lower the o-ring area, the bottom end of the return line pipe into the oil pan.
When I start the engine at park, after about 5 min, white smoke will arise from the area where the driver side turbo return line is located.
Can I conclude that this is the turbo return line leak? Is there any other that I should check? The oil seems to be every where. I just want to find the one main area and fix it.
Thanks.
Volvo S80 '2000 Turbo Return Line Leak?
- 3866 Views
Last post by FlyingVolvo
- 559 Views
Last post by FLXC90
- 680 Views
Last post by jeffsws
- 794 Views
Last post by oragex
- 709 Views
Last post by Seaway
