740 Door Handle screw won't come out
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
JAGCHiker
Year and Model: 745 '88
Post by JAGCHiker »
Something in the Door handle on my 88 740 broke. I've gotten the interior panel off and the 2 screws on the rear/outside panel came out cleanly. The single 10mm bolt securing the front of the handle won't come out. It turns with varying resistance; and doesn't appear to be backing out. I thought it might be the gears in the socket wrench, however it acts the same with a wrench. I haven't seen the inside of the handle; but the resistance acts like the threaded portion of the handle separated from the handle proper? Any ideas on how to solve this?
I can't tell if the handle connection or the rod connection broke- there is no resistance on the lever when squeezed. There was a 'snap' when I attempted to open the door. Figuring how that all works will come; if I can get the handle off. I can't see or feel a loose rod in that area.
