Hey all...
I think I have exhausted all solutions posted before posting this. FYI
Driving my 1994 850 wagon last week I noticed that suddenly the blower stopped. I pulled over, tried all blower options on the ACC unit, but couldn't get it restarted until I turned the car off, waited a minute and restarted the car. The blower began again as it usually does. About two minutes down the road it quit again.
I got an used ACC unit and replaced it. It worked for about an hour of driving time and then the same issue; the blower just stops until i restart the engine.
I have also checked both units for signs inside of blown circuitry/resistors. Both units look fine.
and both fuses 5 and 31 both look good. I replaced them just in case.
What should i do next? Thanks ahead for the help!
850 heater issues
volvomoose
- Year and Model: 855t 1994
1995 850 Turbo Wagon (180k)
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It's likely a problem with the fan resistor. Search for those issues on the forum or google.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Keep in mind that it's bad motors that kill the resistors (in an MCC) or power stages (in an ECC),
not the other way around. When the motors go bad, they start pulling too much current, stressing
the speed controller. Resistors burn out altogether and power stages either die full on or totally off.
The motor should always be looked at and verified good before it's controller is considered.
It's also worth checking all the connections at both devices. Many owners have discovered overheating
connectors at both ends of the wire from the controller to the motor. That'll kill controllers, too.
I still have the original blower in my 93 850. I had to change the ECC because a capacitor died. They placed the capacitors right next to the motor controllers. There are 5 motor controllers and 5 capacitors. The #3 cap. died because it got the hottest and there's poor circulation in there. Volvomoose's blower may still be good. I was leaning toward fan resistor.
burnout8488
- Year and Model: 1999 S70 AWD
Gotta be Automatic!BEJinFbk wrote:When was the blower motor last replaced?
And do you have ECC or MCC? (What's ACC?)
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
volvomoose
I have the ECC.. sorry not the ACC. I don't think the blower motor has ever been replaced - I will have to check the blower motor and the resistor. I will search for a posting on both of those - I assume there is since this is the best forum in the world!BEJinFbk wrote:When was the blower motor last replaced?
Thanks all!
Chris
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
- 11 Replies
- 2593 Views
Last post by dimataeus
- 32 Replies
- 17923 Views
Last post by sleddriver
- 23 Replies
- 6783 Views
Last post by callahanoffroad
- 7552 Views
- 1308 Views
Last post by MadeInJapan
