I searched here and found a few posts with "torque rod" in them. But, none of the ones I read really answered my question. Sorry if I simply overlooked a post answering my question.
How much movement should there be when you rock the torque rod whith your hands? I get a lot of movement from the bushings on each end and the one in the center as well. I would assume there should be pretty tight.
Thanks
Torque rod movement, how much?
Can't really help you on the end bushings, although I do think they will/should have more play than the upper mount. On the upper mount, I just replaced one on a car that had 45k. The old bushing had all kinds of slop and there was noticeable vibration at the steering wheel. The new mount had no play and eliminated any vibration we were feeling.
JRL
- Year and Model: Several
- Been thanked: 16 times
It should be pretty hard to move when stationary but even with a brand new bushing, if you stand outside the car and someone brake torques the motor, that engine will move "forward" at least two inches!
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
I presume you mean the upper torque stabilizer? The horizontal bar that connects to the upper engine mount?
My 2001 S60 (142k) had a sloppy torque stabilizer. I replaced the upper engine mount bushing. My 2007S60 (63K) is still pretty snug. So I guess I can compare three vintages of these (0, lightly and heavily worn).
The proper "feel" seems to be:
I am able to firmly grasp the bar with two hands and roll it forward and backward about 15 degrees each way.
Its also helpful to check the "feel" of its play side to side and sliding back and forth. It should roll a little as I described but it should not slide more than 1/4" either way.
This is not an official spec. This is just what "feels" right on the ones I've looked at.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
JRL
Are you referring to the upper torque bushing or the horizontal X bar?
The X bar has a lot of slop in it
You can buy two small bushings to make that solid if desired (it does help the front end feel)
Yes, I'm talking about that bar in the engine compartment. I've seen it called several things. I don't know the correct part name.
I was just cleaning the engine and noticed how loose it was when I was wiping it down.
If there is too much play, what would I feel when driving. Or, better, what noticable improvement would gain by servicing it?
Thanks again. Great site.
JRL
Supposed to be pretty loose
There is no "servicing it"
Either you install poly bushings or leave it, but this is the way it comes from the factory for smoothness.
JRL
IPD has them for about $50
A 10 minute install
A 10 minute install
