Cam seal leak
1996 - 2004 S40
1996 - 2004 V40
1st_Volvo
Year and Model: S40 Turbo, 2001
Cam seal leak
Post by 1st_Volvo »
Does anyone know how to identify a cam seal leak?
Thanks!
1st_Volvo
Post by 1st_Volvo »
Anyone?????
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Look for oil coming out one of the 4 covers on the cams.
Behind the distributor, behind the cam sensor (both on the drivers side) or from behind the timing belt gears.
'98 S70 T5
2016 Chevy Cruze Premier
1st_Volvo
Post by 1st_Volvo »
How about oil coating the inside of the timing belt cover be evidence of a cam seal leak?
Thanks jblackburn!
jblackburn
Yes, that's definitely an indication. Mine were leaking on the belt, and oil usually weakens rubber. I'm not sure how long it had been leaking, but it made it 3 years/the full 70,000 miles it was supposed to (time-wise, belts are supposed to last up to 7 yrs). But if your belt has been covered in oil, I would definitely advise replacing it too.
'98 S70 T5
1st_Volvo
Post by 1st_Volvo »
Thank you very much!!!! I'll definitely work on that too...
hobbitwho
Year and Model: 2000 S40
Post by hobbitwho »
My 1.9T was leaking by the Variable Actuator (Back Left of the Head as looking in), the problem I had was the NEW AFTERMARKET Cam Seal was not the right size and had to be replaced again with the seal from VOLVO.
1st_Volvo
Post by 1st_Volvo »
Thanks hobbitwho. That sounds like the area I'm seeing oil leaking.
Just found out that the head gasket is blown; hydrocarbons in the coolant, wetness in the #4 cylinder, and coolant pressurized after running for 1 minute.
Jim
