My low beams stopped working ? With dash switch to low beam position no headlights or tail lights switch to middle position all corners work and brake lights are good no bulb failer light. all fuses are good.is there a relay I missed?
thanks in advance.
93 945 non tubo no headlights
Lou Rosenbaum
- Year and Model:
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The only 'relay' for the low beam headlights is the bulb failure relay which can go bad.
Test for voltage at the input side of the low beam fuses (19 & 20). If you don't have voltage there, the bulb failure relay is bad. You can pry the cover off and attempt to re-solder it or get a used one.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Lou Rosenbaum
- Year and Model:
checked voltage at fuse 19&20 no volts, which is the bulb failure relay?
- billofdurham
Same place as in your other post: Back row left in the relay board under the radio. It is big, red and round.
Bill.
Bill.
Previously:
Previously:
- 941 Views
Last post by Bricks_and_boxcars
- 696 Views
Last post by azureblue
