1997 850 220k miles
The Fog Lamp Indicator on my dash is lit. I replaced all rear lights and it's still on. Front lights are all operational as well.
Note: I only have one rear fog lamp as I understand it. Looking at the lens covers, the driver side has space for a bulb and the passenger side does not (it's blocked off).
Any clues as to why fog lamp indicator is lit after I have changed all of the bulbs?
Thank you in advance.
Rich
Fog Lamp Indicator
- Has thanked: 292 times
- Been thanked: 765 times
Is the single fog bulb in the rear, illuminated? That is the only time the fog lamp indicator comes on in my car - maybe the switch is broken. Or switched on (!).
Just to be clear, so your car does not have front fogs or a switch for them?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Best of all possible fixes!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It is good to use the rear fog light in FOG. It only has 1 light to help people see you and not to be confused with brake lights. The switch lights up when they are on.
KlubMarcus
- Year and Model: V70 XC, 1998
Here are pics for replacing the rocker switch bulb.
- Here is the old burned out rocker switch bulb.
- CIMG1811 (800x448).jpg (215.7 KiB) Viewed 444 times
- Behind the rocker switch is the tiny bulb, unscrews with a quarter turn.
- CIMG1808 (800x448).jpg (176.09 KiB) Viewed 444 times
- Unsnap adjacent unused switch covers to make rocker switch removal easier.
- CIMG1809 (800x448).jpg (215.74 KiB) Viewed 444 times
