I'm trying to change the MAF on my '96 850. It has security pin screw heads. No problem, I thought, as I have the security bit set and have used it elsewhere. Trouble is, the pin in these self-threading screws is apparently a bit bigger than the hole in my torx bits, so I can't get the bit to bite. I bought another bit set to try and likewise the hole won't go over the pin.
Any suggestions how to get these cleanly out?
Thanks!
Stymied by torx security screw on MAF
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
I just did this last weekend:
I used a locking long nose plier. There is a small lip on the screw heads and you can get the plier to bite onto that. Its a weak screw into the plastic so it unscrews easily. I started it by hand and tightened with the same locking (vise grip) long nose pliers when I was done.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Why even mess with those?
When I replaced my MAF, the OEM
replacement was the whole tube section.
Took about 5 minutes to change.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
The security bits I have were bought at Harbor Freight. They've worked on other screw heads with a pin, but not on the MAF. The screws on my '93 don't have the pin at all. So is the '96 a design upgrade or a bottom line upgrade? I guess Volvo really doesn't want us to just replace the MAF without the tube.
KEWROCK
- Year and Model: V70R 1999
I've run into them a few times. I usually get an awl or tiny screwdriver and break those little posts out. They crack off very easily(for me anyway). Then use a regular torx or alan key.
1999 V70R T5 AWD Red
Paul-93-850
- Year and Model: 1993 850 non-turbo
Use a little Dremel cutting wheel and cut a straight slot across the head. Remove the screws with a large straight slot screw driver. It's quick and easy. Every mechanic should have a dremel set.
Fixed that for ya...Paul-93-850 wrote: 04 Jun 2018, 19:26 Use a little Dremel cutting wheel and cut a straight slot across the head. Remove the screws with a large straight slot screw driver. It's quick and easy. Every mechanic house should have a dremel set.
- Has thanked: 311 times
- Been thanked: 817 times
+1, I don't think I've ever seen a Bosch MAF come without the tube, what is the source?BEJinFbk wrote: 25 Feb 2012, 15:42 Why even mess with those?
It's not that Volvo doesn't want you to replace the MAF without the tube, it's that you don't want anything other than a Bosch MAF. If it's not a Bosch MAF, it's almost guaranteed to intermittently stumble and throw codes. They don't work.
- 23 Replies
- 937 Views
Last post by 8pack
- 31 Replies
- 10340 Views
Last post by erikv11
- 2235 Views
Last post by mydamnvolvo
- 2071 Views
Last post by iRenaissanceMan
- 2891 Views
