Door will not open Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Bill W
Door will not open
Post by Bill W »
I have a 1990 740 Wagon. It has power locks. I can not open the rear door to the cargo space. Does anyob=ne have any suggestions?
Guest
Post by Guest »
Bill W wrote:I have a 1990 740 Wagon. It has power locks. I can not open the rear door to the cargo space. Does anyob=ne have any suggestions?
Have you tried to climb to the back from withen the car??...there is a door opener handel there that you could try.
RML Guest
Post by RML Guest »
Bill:
If the symptoms are that you pull on the handle and it does not trigger the latch, the problem is likely that you need to adjust the linkage a bit. I had this problem on my '86 740 wagon.
I can describe what I did on my '86 but do not know if it is different on a '90. You will need to open the rear door from the inside, then remove the inside door cover. The lock assembly comes out with two bolts. The linkage to the handle is simply a rod threaded into another rod. You will want to twist it to make it longer or shorter, whichever is appropriate. Test it before you put the door cover back on.
Hop this helps. It solved the problem for me. Lubricate the lock while you are in there.
Richard
