My 97 850glt has dual climate control.
No matter how I set the controls, the drivers side dash vent blows hotter than the passengers side.
I don't have AC right now because of a busted line,... So I am talking just vent.
Maybe I am not operating it correctly but with both dials set at SAME degrees, the drivers side is hot air and the passengers side seems more accurate to the dial position.
I don't notice a change in the scenario in AUTO mode either...
Just seems like the drivers side is stuck on heat, although the lower temp settings ARE cooler than the higher settings, it's still VERY warm air coming out.
What would cause/cure this problem??
RZ
