Links to MAJOR forum topics - 850, S70, V70, C70 & XC70
Locked
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Volvo Stage 0
The single most important page on this entire site.
Tune Up 850/70... The Basics
New to DIY'ing? Start here. These are wonderful overview videos for the novice DIY'er. The video's host goes over where parts are in the engine bay, what they do, and why they're important.
Owners Manuals
1993 850 Debut, and differences between it and the 1994 850
Summary of characteristics for the 1994 850... assume things are unchanged from the 1993 850, except for these changes...
Differences between 1994 and 1995 850
Summary of characteristics for the 1995 850... assume things are unchanged from the 1994 850, except for these changes...
Parts brands - OE Volvo, trusted aftermarket, and bad
Which aftermarket parts brands do we trust and which should be avoided? Which brands make the parts that Volvo sells under their brand and is there any difference between theirs and Volvo?
1993 -1995 use a Unique Volvo Variable Intake System (VVIS) discussed here
Parts: what failed on your 1992-2000 FWD or AWD Volvo?
The special transition years of 1999 and 2000 and what makes them tick...
DIY Delta Link rear suspension fix
I have had a persistent “clunk” in my rear suspension and a “wandering” sensation at highway speeds.
No Start Troubleshooting for 850, S70, V70, C70 & V70-XC
Intent here is to give a quick referral to no-start posters on how to get going again.
Wiring Diagrams
How to Eliminate Vacuum Leaks as a cause of your symptom
How rare is your 850, S70, V70 or XC-70?
PCV System Repair on a 1993-1998 Volvo 5-cylinder and PCV System Repair on a 1999+ Volvo 5-cylinder
You've got to do this every 5 years or so, might as well do it right. Here's two outstanding tutorials documented with great photographs.
URO parts topic
850 140k Major Maintenance & Timing Belt DIY
What to do when your 850 hits 140k miles + an outstanding 850 timing belt replacement tutorial. Timing belt tutorials and advice:
How to Read Volvo Diagnostic Codes
Up to model year 1995, and some 1996 models, you read codes via a small box under the hood.
How to Read Volvo Diagnostic Codes, OBD-II
1996 and up Volvos have an OBD-II port. You need to read the codes with a code scanner.
Volvo V70 and S70 Repairs, Tutorials, Upgrades and Information
Browse information, upgrades, repairs and more in the Volvo Repair Database. Includes information that may be helpful to owners of similar FWD Generation 1 Volvo models like XC70, C70.
The Encyclopedia of 850 Repairs
Almost every major repair a pair of hands can do to an 850. A guy named Jim writes this, and he's a member here too. We're proud to have him!
Idle/Power Problems? Troubleshoot Here
Volvo 850 Repairs, Tutorials, Upgrades and Information
Browse 850 information, upgrades, repairs and more in the Volvo Repair Database. Includes information that may be helpful to owners of similar FWD Generation 1 Volvo models like V70, S70, XC70, C70.
Volvo Terms and Abbreviations
MAF, SAS, FWD... what does it all mean? Make sense of the letter soup with this Volvo term glossary.
master o-ring size and discussion links
How to figure out what size o-ring goes where when in a bind, AC, power steering, dipstick, heater core, firewall connections…
Always harvest these parts at the pick-n-pull
"Here are the things that he listed as to never leave, as they will be needed someday by someone (or you!) and should be saved from being eventually crushed. Add away with parts that are becoming scarce, will eventually break or are just good to have on hand."
Helpful Visuals850 ECU And Its Dependents - Relationship Chart, 850 Suspension - Exploded View
POLL: Various Polls
Vote on your experiences with Volvo 850, S70, V70, XC70... New to DIY'ing? Start here. These are wonderful overview videos for the novice DIY'er. The video's host goes over where parts are in the engine bay, what they do, and why they're important.
Also -> Amazon link
Locked
