Group:
’98 S90 has an A/C problem and I don’t know where to look.
Compressor cycles 5 sec ON and 5 sec. OFF after driving on a sunny 80 degree day.
Same while stopped afterward.
Electric fan behind radiator runs, as it should.
In-car fan runs and responds to the various settings.
However air is not coming out of the vents, in any of the positions on the dial.
If I hit a bump it can start blowing out the vents.
Hit another bump and it stops.
No effect from changing any of the A/C control setting.
Not real cold, so I may need Freon, but how is that related?
My big green Service Manual wiring book shows a device called: “Servo motor, mixing shutter”.
It seems to be buried in the dash area.
There is also a “ECC climate control module” that seems to be the box that all three adjustment knobs are mounted on.
Anyone got any suggestions as to where to start?
This is a late production US car so I expect it has the electronic control system.
Does the panel with the three controls come out by itself?
How to get the wood trim off without breaking it?
Thanks,
Rich
S90 A/C woes
