Just found out my fuel pump is bad. The shop it is at will not change it (electrical specialist). I am away from home and have minimal tools. Now for the questions.
1 Is the pump accessible without droping the tank?
2 Are ther 2 pumps? I have found conflicting information on this.
3 Is this doable with a socket set and on board tool box?
1996 960 wagon Fuel pump
JDS60R
- Been thanked: 3 times
Always relieve fuel pressure first.
Hope this helps - You can do this .
96 960 wagon fuel pump removal.pdf- (183.89 KiB) Downloaded 154 times
Retired
JDS60R
I am only seeing the single in tank pump. The 96 did have 2 different fuel injection systems but all the data I have points to one pump only on the 97's with no specific info on the 96's.
Retired
jimmy57
- Been thanked: 320 times
One pump only on that one. It is not too bad but the clamps on the filler hose which connects to the sending unit/fuel pump cover are often turned where they are tough to get to. 1/4 inch ratchet with a 7mm socket will usually get it.
- 1256 Views
Last post by lummert
- 42 Replies
- 10411 Views
Last post by Maestrours
