2001 XC70 - 200k miles Suspension Replacement?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
psflyr
Year and Model: xc70 2001
Post by psflyr »
My '01 XC70 has 206K. I've never replaced either coil springs or shock / struts. My mechanic says the car is fairly 'tight' but everything I read screams replacement. What should I consider replacing if anything at all? A total 'makeover' of all components or just struts, or something in between? As far as sway bars, bushings, ball joints, etc... I've always replaced those items per my mechanic, just not the aforementioned components. I'm leaning towards doing the work. Part 2 of the question then asks which brand is recommended for this vehicle? Thanks in advance for your help!
Cheers,
Paul
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Unless you are wildly in love with the car, I'd listen to the mechanic and leave it alone (or maybe just struts and bushings) but you have 206 on it. How much loner will it go? 300, maybe to 350K?
I'd go stock for struts or Bilstein. Stay away from URO rubber parts, FEBI and Lemfordor (sp?) are OK. Does the XC use the Nivomat rear shocks? They are supremely expensive but last a pretty long time. Springs can go for the life of the vehicle. Does the car drive OK? Wander or shake a lot? Do you get a nasty shake in the steering wheel after hitting bumps? All this work may well be worth the effort is the engine and tranny are perfect and the body is holding up.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
psflyr
Post by psflyr »
The car is in good shape. Mechanic says 300K shouldn't be a problem. He offered to buy it actually for his high school kid. Rides pretty solid with no vibration whatsoever at any speed. Have not had any issues with either transmission or engine, so I'd like to keep the car for a while longer.
psflyr
Post by psflyr »
Do you have a suggestion for which Bilstein shock works for the 2001 XC70?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Your suspension has defied the odds by holding up to 200k miles. Thats great!
Sometimes fixing things -- broken or not -- breaks other things. It happens to me.
I'd let sleeping dogs lie in this case.
If you've got some car money burning a hole in your pocket get a chip, or nice tires. Maybe a winter set on a set of simple steel wheels and summer rubber for your oem wheels.
Also -> Amazon link
ONV70XC
Year and Model: 1999 V70 XC
Post by ONV70XC »
Mine 1999 V70XC shakes a LOT even after rechecking the tire balance shakes after 65 mph like an earthquake. Try to avoid roads over 60mph speed limit... To that degree. I noticed that right inner tie-rod stock and not moving while I believe it's suppose to twist. Struts aren't tight either in the front so there are lines of suspects to inspect and try out. The car has 160,000mi.
