Need to replace condenser
wolfman1968
- Year and Model: S80 1999
I have a leak near/ on the Shrader Valve of my AC condenser (High pressure side) on my 1999 s80 2.9 non-turbo. I took it to the shop and they replaced the shrader but the freon kept leaking out. The shop suggested I replace the condenser since the valve assembly is all one piece on my model. Any advise on which aftermarket brand to try or to stay away from? Also, do I replace the accumulator/ drier as well?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I'm not sure you'll find many different brands. Likely OEM and a couple of aftermarket.
You do need to replace accumulator. WHen system is opened after 3 years or has to be open for very long then the drier may not be able to do its job well enough to protect the system.
- 2580 Views
Last post by firstv70volvo
- 630 Views
Last post by Matty Moo
- 767 Views
- 1172 Views
Last post by JNavas
- 3678 Views
Last post by XCMat
