My sons 850 blew a rod and is headed to the wrecking yard so I want to grab the trans as a spare for my 850.
Is there an online tutorial on how to drop one out?
How much work is it to do?
Thanks
Dave
How do I drop the transmission out of 850
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I don't know the individual steps other than to say it is a lot of work, pulling axles, crossmembers etc etc. Would be easier to drop a good used motor in the car and continue onwards.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's how to pull it all out the top (probably easiest).
1995 volvo 850 auto engine and transmission removal
The transmission itself could probably be removed from the bottom - it's usually mating them back up that's the hard part, but you don't want to do that it sounds like.
'98 S70 T5
2016 Chevy Cruze Premier
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
Dave,
It would come out with a couple hours work if you have the right tools and facility. The sub-frame needs to be dropped way down on the driver's side to allow the transmission to slide out the wheel opening. The engine needs to be supported during the process, ideally from above. Removal is pretty straightforward, and much easier than install. Have an extra set of hands help with actual removal from the car, as that sucker is heavy!
If you are a scavenger, you might also want to save: axles, rad, starter, cam sensor, fuel pump, fuel pump relay, battery, MAF sensor, etc... It's always nice to have a box of spares handy.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
Don't bother dropping it at all.
Get a crane and lift the whole powertrain out of the car.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- 28 Replies
- 12162 Views
- 645 Views
Last post by RickHaleParker
- 567 Views
Last post by foggydogg
- 12 Replies
- 2529 Views
Last post by Chuck W
- 1880 Views
Last post by DePonce
