vvt squirting oil
1996 - 2004 S40
1996 - 2004 V40
praia grande
Year and Model: v40 t4 2001
vvt squirting oil
Post by praia grande »
hi,
my 2001 v40 t4 is squirting oil all over the inside of the timingbelt cover and it comes from the little valvething on the vvt.
anybody seen this before? normal?
means that i have to change vvt?
thanks
hans
JDS60R
Been thanked: 3 times
Post by JDS60R »
This is not normal. Replace the failed part and gasket before the oil causes the timing belt to slip. I would also replace the belt after the leak has been fixed and the area cleaned of all oil.
Retired
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The VVT units seem to be leaking with age. I have replaced one and have seen others. There are no seals to seal the area where it leaks.
Replacing it requires a cam locking tool to get cam timing correct to be sure no codes .
