My 2006 v8, third brake light is on all the time.
All the lights work, come on when there supposed to, and turn off as well, except for the third brake light.
The third brake is on a different circiut then the other lights, for safety, designed to work seperate in case lower brake light don't work.
I was advised the ECm could have corrision in it.
Is there a relay that could be bad?
Is there a wiring diagram I could down load?
Any suggestions?
I un plugged the harness for third brake light so my battery doesn't drain.
Third Brake Light On, Won't Shut Off
08 XC 90 V-8 157,000 Spouse
06 XC 90 V-8 141,000 Daughter
06 XC 90 V-8 234,000 Son
03 V 70 2.5 Non Turbo
