Volvo Dealer Told Me That My New XeMODeX ETM Is No Good.
Carly245
Year and Model: S70, 1999
Post by Carly245 »
Two years ago my 1999 S70 started going into limp home mode once every two months and for about a year I've been going back and forth between the Volvo Dealership and the Independent Volvo repair shop, and none of them had any idea what was going on with my car, and neither of them seemed to really care.
Anyway, I got fed up, because it's my only car, and so I made the independent shop put in a new ETM because nobody else had a better idea. They said they would order "a really good one" from Canada (I'm assuming this is the XeMODeX ETM), and my car had no trouble for about 7 months...until the other day.
So, I took my car into the volvo dealership (only because I had a coupon and the independent shop seems overwhelmed whenever I go in), and the guy I dealt with told me this, "Looks like you've got an after market ETM- that seems to be causing the problem.", which I thought was quite amusing considering that they were clueless about a year ago when I asked them why my car was stalling- nobody at Volvo blamed the ETM then, so why now? He said that since it was not manufactured by Volvo, it would mechanically work with my car, but it wasn't compatible with the computer.
Has anyone ever heard of this? Does it sound like the mechanics just have no idea what it is going on and decided to blame the non-Volvo-manufactured part that stuck out like a sore thumb? It's almost as if they know my car is a lemon, because it falls in that 1999-2002 range of poorly designed Volvos, and they just don't want to deal with it.
So, if I have a good ole XeMODeX ETM, then what is causing my car to go into limp mode? The MAF? Volvo wants me to buy one of their ETMs...again! I don't think the ETM is the problem anymore, unless XeMODeX ETMs go bad after 7 months. What else can cause my car to go into limp mode? By the way, my car does NOT store any codes...AT ALL.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
May have to do the work yourself. ETM & Limp Mode
https://www.matthewsvolvosite.com/volvos ... ule-fiasco
99 S70 Suppose to be same as 99 S80 ETM
http://volvoforums.com/forum/volvo-s80- ... wap-40232/
2001 S80 ETM - Volvo Rough Idle Problems (ETM issues) - how to fix
howardc64
Year and Model: 2000 V70XC SE
Post by howardc64 »
Doesn't sound like Volvo has anything to backup the XeMODeX ETM is bad. You can ask them to prove it to you by running an ETM test. The result between good and bad ETM looks like the files in this link
http://www.volvoxc.com/forums/showpost. ... stcount=54
2000 V70XC SE 167k miles
2001 XC70 SOLD
2001 V70 T5 SOLD
Sammamish, WA
http://[email protected]
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The links you provided require membership to Volvo XC forums. Would you be able to post the PDFs if possible?
howardc64
Post by howardc64 »
precopster wrote:The links you provided require membership to Volvo XC forums. Would you be able to post the PDFs if possible?
here is an ETM test result on an ETM with 40k miles on it that is good
https://www.box.com/s/73e88ff945d4c2df6849
here is an ETM test result of an ETM with 116k miles on it that is starting to go bad
https://www.box.com/s/fea71f1def920be59335
The test causes the throttle plate to open and close 4 times and compare the 2 TPS sensors (blue and green lines). The difference in degrees are the black lines (the Y scale is different on the 2 plots, Volvo diag tool (VIDA/DiCE) automatically scales the graphs)
XeMODeX will look just like the good ETM result because they only replace a single TPS sensor and wire the output to both TPS inputs.
2001 XC70 SOLD
2001 V70 T5 SOLD
Sammamish, WA
almostarctic
Year and Model: v70xc 1999 C30 2008
Post by almostarctic »
Call Xemodex. Their customer support is very good. Your Xemodex has a lifetime warranty. Go to your indie. Maybe the wiring harness or relay is bad? There might be a good reason why your indie is busy and your dealer has available appointment $lot$ and is giving coupons and free coffee and donuts.
almostarctic
Alternatively could be your MAF needs cleaning. A DIY doable job.
precopster
Thanks howardc64
To the original poster. If your car is non turbo it's only about 10 minutes work to remove the ETM and take a look at what type of sensor you have on the opposing side. If it says "Sacer" it's a XeModex.
If it says Magnetti Marelli on both black sides of the housing well that's about as unspecial as a happy meal for a retiree.
The XeModex is a great ETM but you still have the original Magnetti Marelli circuit board which can also fail (though this is less likely)
I've posted a photo of the ETM I repaired myself with the same sensor that XeModex use.
20120415_092412 (Large).jpg (118.12 KiB) Viewed 6897 times
howardc64
Post by howardc64 »
precopster wrote:If it says "Sacer" it's a XeModex.
Good point, nothing confirms the op's ETM is XeModex. Best check that first.
I think XeModex puts their own sticker in the front of the ETM replacing the Volvo white or yellow label. An easy way to ID without removal assuming Op can find the ETM :)
Here is the Xemodex label on the ETM
http://img.photobucket.com/albums/v290/ ... tm/ETM.jpg
http://img.photobucket.com/albums/v290/ ... ETM009.jpg
Here is the original Volvo ETM labels. It can be white (original) or yellow (replaced)
http://www.bba-reman.com/images/volvo.gif
Here is ETM's location on the turbo.
http://home.comcast.net/~donwillson/tech_info.html
Here is ETM's location on the non turbo. The label is facing the bottom so probably need a mirror.
http://www.car-pics.net/volvo-v70-2-4-auto-etm-pics
Anyway, ETM test would definitely confirm if Op's ETM is problem or not regardless of the manufacturer.
2001 XC70 SOLD
2001 V70 T5 SOLD
Sammamish, WA
almostarctic
If you have a Scangauge you can run an Xgauge for MAF and TPS (the programming code is on SS I think). It will show you if your MAF output or throttle position sensor is varying under constAnt load
