new battery caused issues?
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
meggs117
Year and Model: s80 t6 1999
Post by meggs117 »
my cars battery just went out yesterday so we bought a new very pricy one. we installed it the car started but the ac pannel and gear shifter leds didnt come on. and my ac isnt coming on now. im not sure why. could it be fuses? or relays? im not a car person im completely confused. the cd player right above all of the ac pannel in my dash works just the ac doesnt work nor the leds in this area.
meggs117
Post by meggs117 »
also just went out to mess with it the buttons on the bottom arnt working either . like my traction button and trunk lock things like that as well as my weather button on the side of my shifter
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Now that the Battery is fine try a computer re-boot. Take the ground cable off the battery and touch it to the positive post for a count of 10. Then re-connect and see if the items return to function.
Sometimes electrical problems makes some of the modules freeze up just like your laptop can. Just like your laptop, it can require removing battery power to get it to reset itself.
meggs117
Post by meggs117 »
we took the battery out again now my computer is saying air bag urgent service. and the same things remain off?
Dirtbag454
Year and Model: S-80 2000, C70 2004
Post by Dirtbag454 »
Don't know if this will work in your case, but try the lock/unlock X 3 with your remote. It resets non-op stuff that seems to forget what is supposed to do when a battery loses it's charge. This may be a panacea, but it sure seems to return functionality when battery issues remove it. Only today, after an arduous campaign to replace heater hoses and O-rings, I noted an absence of A/C function, central locking, sunroof function, and windows. The engine ran fine, but other stuff, not so good. I shut it down, got out and pointed my magic wand (remote) at the drivers door. (could have clicked it in my pocket, aimed at the ground, with the same result, it just looks better like this) Like Dorothy in Oz, I clicked it three lock/unlock cycles, and got all my missing function back. I think that my dog has fewer fleas too, but that may be just a coincidence.
Good luck.
'04 C70 Ragtop (103K)
'00 S80 T-6 (donated @ 140K)
'95 850 (traded @ 120k)
'83 240DL (crashed @ 303k)
And then there's the '70 240Z and the '58 Chevy Apache, not to mention the motorcycles...
2013 BMW K1600GTL
Dirtbag454
meggs117, the above post may sound facetious, but it does work. The lock/unlock cycle, which I believe can also be done with your key, resets some computer hardware that controls the very stuff that you have lost the use of. I hope that it is as simple a fix as this. Good luck.
Dave
2013 BMW K1600GTL
jimmy57
Post by jimmy57 »
I'm not sure where 3 lock cycles came from but on 2001 and later Volvo added "transport mode" to networked cars and when battery is disconnected the car will default to transport mode. TM does put some modules in off or reduced function but GSM where gear position LEDS is located is not one of those. One lock cycle plus a 3-5 second wait exits TM and puts all modules in full function.
meggs117
Post by meggs117 »
no good the key stuff didnt work i think i may need to take it to the volvo dealer and ask about the ccm reboot. anyone know about this and how effective it is ?
