hose clamp at lower radiator blown off
98expeditionXLT
- Year and Model:
Today my son was driving and the 850 non turbo overheated again. Had it towed home and the lower radiator hose was blown off from the radiator with the clamp nowhere in sight. No damage to the radiator nor the hose. This is the second time this has happened in 8000 miles. The car has 279k miles on it. I'm wondering if the fact that the hose clamp is an aftermarket one not the beefy Volvo ones is the reason. This engine never runs hot and it is exposed to a wide variety of driving conditions. The temp gauge always reads at the middle of the gauge once the engine is warmed up, in summer and winter and in city traffic. Any ideas what may be causing the problem?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Cheap URO hose? I hate that company...so much.
Go to Carquest and get a Gates radiator hose clamp. You shrink it on to the hose and port with a high powered hair dryer or heat gun. It has much more surface area than a normal clamp and should keep that on there.
I had a hose that kept leaking, and this turned out amazingly for me. Not a drip since.
'98 S70 T5
2016 Chevy Cruze Premier
98expeditionXLT
- Year and Model:
The hose clamp was the generic hose clamp that Advance Auto sells. I used to have two clamps on there but when I had the rear main sela done about 20k miles ago my mechanic only put one back on.
jblackburn
Many of the aftermarket hoses that are put on will squish down too easily and leak or blow off. The Gates Powergrip SB clamps look like this and heat shrink around the entire outlet fitting to ensure a good grip on the hose.
'98 S70 T5
- 18 Replies
- 6897 Views
Last post by Mark1967
- 16 Replies
- 6926 Views
Last post by RickHaleParker
- 20 Replies
- 4235 Views
- 16 Replies
- 3307 Views
Last post by jreed
- 711 Views
