ABS Problem
1996 - 2004 S40
1996 - 2004 V40
s40Ghost
Year and Model: 2000 volvo s40
ABS Problem
Post by s40Ghost »
I Have a 2000 volvo s40 and the abs module is going bad, can anyone tell me where the abs module is located so I can replace it? And how can I avoid using my whole paycheck for a new one? Thanks!
elchopperfreak
Year and Model: S70 T5 1999
Post by elchopperfreak »
The abs module is placed on the left side of the car (passenger) near the front headlight.
You will see a block with hard brake lines going into it, the module is the black box close to the fender.
I am not 100% sure about the bolt sizes, but I believe its a 10mm to loosen the nuts on the junction box, which you may raise a bit to access the Torx 20 bolts that hold the module in place, remember to remove the plug.
I can take a pic tomorrow with light if you need more details
elchopperfreak
Check this post, it does have pics of what you need
https://www.matthewsvolvosite.com/forums ... =8&t=28717
