In my XC90 from '04, have resently expirenced that that radio stops (musik and display) and the display in the RTI-screen gets black, and after a fem seconds the screen slides down.
Sometimes it last at few seconds, other times a coupe of minutes. In every case it starts again, if the engine has been turned of in a couple of minutes.
Has anyone a idea what's wrong? Is it a cable, Connectors or ..?
Radio and RTI stops ???
jimmy57
- Been thanked: 320 times
Any loose connection on the fiber optic leads between the components will cause this. On XC90 the left front seat has the VAN/RTI dvd reader and it is easy for an umbrella or other item to slip under there and you can pull the lead out fetching the item. look there first.
